Error 1003: On open vi by reference in runtime environment
I have an issue where I have the following main.vi contained in a project (MainProject.lvproj). This main.vi calls A.vi contained in project (HelperProject.lvproj) by reference.
Attachment 1):
A.vi calls a vi from the toolkit "ni-industrial communications for ethernet/ip"  .
When I run the main.vi in development environment everything works as expected. The issue that I am facing is when I run the build (runtime environment), it gives me an
Error 1003: Open VI Reference in main.vi<APPEND>
VI Path: <b>C:\Debug\HelperProject\LabView Files\A.vi</b>
I also noticed this in the dependencies folder of HelperProject
Attachment 2):
Any hints on how can I solve this? I have attached all of the necessary files in Attachments. I am currently using LabView 2015 64 bit SP1. Help would be appreciated.
Message 1 of 8
(7,403 Views)
Accepted by sridatta04
In your executable you need to get the correct path to the VI you want to run inside the executable. You can use a property node and get either "path" or "name" for the Open VI Ref function. You may need to change your VI Refnum to a Static VI Reference first, I'm not sure.
Message 2 of 8
(7,392 Views)
I use Start Asynchronous Call all the time, but rarely Call by Reference.  However, the rules seem similar for both.  I've found the following works equally well in Development and in Executable modes:
  • Drop a Static VI Reference.  Browse for the VI that you want to "reference".  As a bonus, if your VI has an Icon, the Static VI Reference will show that Icon (helping with self-Documentation).
  • Right-click and make this a Strictly-Typed Reference.
  • Wire it to a Property Node.  You'll get a "strictly-typed" node, but that's OK.
  • Wire the Path property to Open VI Reference.  Wire the Static Reference to the terminal on top of the Open VI Reference.
  • The VI Reference can now start Call by Reference or Start Asynchronous Call.  The same code will work in both Development and Execution code.
Message 3 of 8
(7,361 Views)
I take the same approach. It also makes the build process easier since LV will be able to figure out that staticly linked VI should be included in the build.
Now if you are targeting a VI from one application that is served by another, you will have to make sure the target VI has a FP.
Ben
Message 4 of 8
(7,338 Views)
Thank you so much for this! It worked well.
Just out of learning curiosity, can you explain me what did the Static Reference>PropertyNode-Path do vs the normal path.
Message 5 of 8
(7,325 Views)
Ben
Hey Ben,
Yes my VI did have a front panel. Thank you for your help! 🙂
Message 6 of 8
(7,323 Views)
VIs in a exe have a different path than when in the development environment. Using that approach lets you cheat and not have to worry about the path inside the exe.
If you really want to see how the path changes, put an indicator on the front panel of the target VI and display the path.
If you can get away with, cheat.
Ben
Message 7 of 8
(7,319 Views)
Ben
Wooha! I didn't know that. I have like 10 other VI's in the project which works well with the method that I used. Only the one I highlighted and included in the HelperProject didn't work (A.vi) because it had an dependency. I will definitely try to put an indicator and read more into it 🙂
Message 8 of 8
(7,316 Views)
