 Castanon
			Castanon
			09-23-2005 07:54 PM
 Dennis_Knutson
			Dennis_Knutson
			09-26-2005 08:30 AM
		09-27-2005
		10:32 AM
 - last edited on
		06-01-2025
		05:26 PM
 by
		 Content Cleaner
			Content Cleaner
Hi Castanon,
You may also want to make sure the VISA runtime engine is installed if the computer you are getting the error does not have the full NI-VISA installed.  If you are still having trouble, please let me know.  Have a great day!
Chris R.
Applications Engineer
 christian511
			christian511
			11-03-2005 08:47 AM
HI Chris R.,
I do have a similar problem with the USB6008. A simple testapp (aquire 1000 samples from one analog channel taken out of the NI Examples) runs fine in LabView 7.1. After I made an executable app out of it I get the Error 1073807346 saying "VISA: ( Hex 0xBFFF000E ) the given session object reference is invalid." The NISpy shows that there are one open command, several reads and writes, a second open (without a close) before the worng behavior occours.
I was hoping you could give me a suitable solution for this. I worked a lot with DAQ on NI-PXI systems but I'm relatively new to the USB stuff. So far I could not get it to run.
Thanks for you help.
Kind regards
christian511
11-06-2005 04:06 PM
 napview
			napview
			01-06-2007 02:38 AM
I really need help to get the installer file for the exe file created in 8.2 version that has the GPIB and serial port setting to work on a non Labview computer. COM1 is assigned to the visa resource control and GPIB0::x::INSTR is assigned to instrument (x is the GPIB address). I searched in this forum and tried to put the file srpdrv in the same folder but that still did not work. Should I install NI-VISA on the target computer and exactly what is the name(s) of the VISA file(s) to be installed? Should I change the COM1 to ASRL1::INSTR in the source vi? Also anyone knows exactly what to set in the exe build settings window and the installer build settings under project enviroment? I talked to the NI technical support and he said to check only the LV run time engine 8.2 and left everything else unchecked but maybe he did not know that I also have the GPIB and serial ports in the source vi. I am so lost now because it is not very straight forward to create something this simple .
Thanks for your help!
 napview
			napview
			01-06-2007 03:48 AM
 I found the issue with the exe on XP. Just installed the NI VISA 4.0 (latest I think), a big file though ~120mb, and that took care of the problem. Not exactly sure of what made it go away but I also tried to installed the files from the 3 device driver discs, this approach was way more messy but it also worked on a different computer (the first one is a slow CompaQ, the other is a not so fast Dell but faster
 I found the issue with the exe on XP. Just installed the NI VISA 4.0 (latest I think), a big file though ~120mb, and that took care of the problem. Not exactly sure of what made it go away but I also tried to installed the files from the 3 device driver discs, this approach was way more messy but it also worked on a different computer (the first one is a slow CompaQ, the other is a not so fast Dell but faster ). Anyway I am currently staying up at 2am in Cali and so glad to get different versions of exe files to work on different computers. This is very critical to the job of mine
). Anyway I am currently staying up at 2am in Cali and so glad to get different versions of exe files to work on different computers. This is very critical to the job of mine for the upcoming CES in VIVA Las Vegas next week. I hope that I deserve a BIG raise
 for the upcoming CES in VIVA Las Vegas next week. I hope that I deserve a BIG raise .
