Error 2147138480 in Set Scan Engine Mode to Actif
Hi all,
I'm fighting in front of this error which occur and does not want to go away (even after trying everything)...
The error (-214713840) is happening when trying to set back the Scan Engine Mode to actif.
It says: "The slave device could not be found. The positional addresses within the LabVIEW project are inconsistent with the actual network topology. [...]"
I was trying to program the detection of the loss of a CompactRIO chassis when this error first occurr.
I have 2 CompactRIO "EtherCAT" connected to a RT computer.
Thanks for all the help or suggestion you can provide me 😉
Cheers,
Laurent
(3,499 Views)
Hi Laurent,
I don't know if your problem has been solved but I prefer asking.
Are you sure of the error code you encounter ? I don't find it in the manual or other places.
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
(3,443 Views)
Undeploy previous / deploy new configuration from Labview project explorer might help. It resolved Error 2147138480 to me.
(3,362 Views)
