Error -50103 en NI USB-6218
Hola a todos,
estoy haciendo un proyecto de adquisición de datos con una tarjeta de adquisición de datos NI USB-6218. A la hora de adquirir los datos por las entradas analógicas utilizo el DAQ Assistant. Por ahora solo tengo dos señales analógicas conectadas y ya me da error. Os adjunto el error que me da y el .vi
Muchas gracias
Message 1 of 9
(3,518 Views)
Duplicate posts:-
http://forums.ni.com/t5/LabVIEW/Error-50103-en-NI-USB-6218/td-p/2049986
http://forums.ni.com/t5/LabVIEW/Error-50103-en-NI-USB-6218/td-p/2049984
Thanks as kudos only:)
Message 2 of 9
(3,508 Views)
yes, I'm sorry! But I don't know how erase it.
Message 3 of 9
(3,506 Views)
No problem you just continue in this thread.
Message 4 of 9
(3,504 Views)
Any suggestions??
Thanks!
Message 5 of 9
(3,482 Views)
Accepted by oscar.pq
Do a forum search for that error.  It's been discussed probably hundreds of times by now.  Try searching "50103".
Message 6 of 9
(3,468 Views)
all i find is people saying the error 50103 is already discussed, i have the same error. :c
Message 7 of 9
(3,314 Views)
Message 8 of 9
(3,312 Views)
i don't really get how to " combine all operations of the same type into the same task."
I get I have to use only one DAQassistant, but i don't know how to combine operations.
i.e. analog voltage sine waves from several outputs
Message 9 of 9
(3,310 Views)
