Error 6 while trying to play .wav file
Not sure what I’m doing wrong here, but it is probably an easy fix for someone.  My rookie status is not in doubtSmiley Happy
(3,331 Views)
Looks like I needed to add the sub VI here as well - I’m new at this.  FYI, I started out utilizing one of the examples that came with the software and then tweaked it.  Where possible, I try to start with something that works and then bend it to my needs.
(3,330 Views)
I figured it out Smiley Very Happy
(3,300 Views)
Ops, here is the alarm vi.
(3,299 Views)
Two questions:
1) Are you satisfied with the replies you have recieved so far? Smiley Wink
2) Did this issue have anything to do with the file you were trying to play becoming unavailable?
Ben
(3,295 Views)
I didn’t get any replies.  Page 113 from the below link stimulated me to play around with it until I found something that did work.  Not sure what I was doing wrong to begin with, but it works now.
http://books.google.com/books?id=-VR-YdFhYx8C&pg=PA113&lpg=PA113&dq=play+labview+wav&source=web&ots=eorkc39hcf&sig=HHYWwYH7DaeccNiQRBu5wju72u4#PPA113,M1
(3,292 Views)
