desktop shortcut for vi application
Hallo all,
I'm trying to create a shortcut for my vi application, but the "working directory"
C:\Dokumente und Einstellungen\win2suse\Desktop\mylabview\myvi.vi
is unvalid.
How could I get around it.
Thanks a lot in advance
(2,922 Views)
just right click the file (myvi.vi) and select create shortcut, cut and paste the short cut to desktop.
How you get invalid warring?
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
(2,899 Views)
Are you talking about Labview working directory or the working directory associated with the VI. If you are talking about the startup directory then:
After you create the shortcut, right click the icon and fill in startup directory.
You will need to click on Tools->Options and change the appropriate path. You did not specify exactly, what kind of path change you want the VI to use.
(2,892 Views)
