Error 65550: CRio 9802
Hi everybody,
I was running example "NI 9802 RT Access" from a 9074 writing to a 9802 but I got the following error:
Error 65550 occurred at cRio-91XX_MountSdDrive.vi
Possible reason(s):
CompactRIO: A problem was found in the file system. Remove the SD card and run CHKDSK.
Running CHKDSK returns no problems. Any idea what's causing this error?
Thanks a lot.
(4,213 Views)
Accepted by Dhasa
Dhasa
This is a known issue for the NI RIO 3.0.1 driver, you can fix it by upgrading the NI RIO 3.1
Please repost if that does not fix it.
-Hunter
(4,177 Views)
Hi Hunter,
I downloaded and installed NI Rio 3.1 on my computer and onto the Rio. I still get the same error (65550) when I try to do anything with the 9802 SD cards. Am I missing something?
Thanks a lot
(4,166 Views)
Hi Dhasa,
If the issue is the known issue with NI-RIO 3.0.1 you will also need to reformat your SD card before it will work with NI-RIO 3.1 or later.  After that you should be able to access your card normally.
Steve
(4,162 Views)
Thanks a lot Steve and Hunter! I had to reformat the SD card into FAT16 on a different computer, restart the Rio and then it worked fine accessing it from the FPGA. I am about to try mounting the SD cards in RT.
(4,159 Views)
