Error 8 at compilation process
Hi:
I have a Labview 2013 program for testing audio in headsets.
This program works fine. It has many functions, devices, drivers, etc.
Some time ago, for some reason when I try to compile it shows error 8 (see picture) and compilation is not successful. It happens not all the time.
Then I close project and open again and it works. In some cases I need to reboot PC W7 64Bit to success compilation.
"Mass compile" function does not show any problem.
Do you have any idea what I need to do to permanently fix this problem?
(3,173 Views)
Accepted by EDGAR_PLATRONICS
Could be this bug.  If so, the reason it might sometimes fail and sometimes not can be because you have a file explorer window open that somehow messes it up.  It would also explain why rebooting can help, because rebooting closes all of your open file explorer windows.
(3,148 Views)
Thank you for your answer. Problem was fixed so far by closing target folder.
(3,099 Views)
