Error 85 occurred at Scan From String (arg4)
Accepted by raj177
You failed to put your received string into the control and save it as default.
The string you posted earlier worked.
See attached VI wiht that string data saved.
Message 11 of 12
(1,148 Views)
Thank you. Yeah you were right. I didn't give a received string to the control.
Message 12 of 12
(1,129 Views)
