06-03-2011 06:09 AM
I am a novice user to use Labview to aquire Data. Acquiction device is USB6008, some problem happen when running the program as attachment. anyone who can help me? thanks
Solved! Go to Solution.
 aeastet
			aeastet
			06-03-2011 07:16 AM
Do you have your code so you can post it?
If you open NIMax do you see the DAQ6008 there? If so do a test and make sure that it is working correctly.
Have you tried to reboot? I know it sounds like a cheap answer but it solves many problems.
Do you have NiMax installed?
06-06-2011 10:24 AM
Some additional info about your system/ setup (LabVIEW version, DAQmx driver version) would be really helpful as well as answers to the questions that Tim posted above.
Depending on your version of LabVIEW, one easy first step would be to reinstall your DAQmx driver or upgrade to the latest version supported by your version of LabVIEW.
06-07-2011 03:26 AM
OS is Win7(64-bit)
LV Version 9.0f3(64-bit)
DAQmx driver version 9.2.3.
in NIMAX USB 6008 can be founded and self-test is well also.
I am not sure whether DAQmx driver version and LV Version are compatible?
Thnaks
06-07-2011 03:33 AM
as DAQ6008 works well in NIMAX,So i think DAQmx driver is ok.
but promblem happened in LV, so i think something wrong with my LV sysytem? am I right?
06-07-2011 05:25 PM
This doesn't necessarily mean something's wrong with LabVIEW itself. Typically, this error occurs when there is a corrupt driver installation or something missing with the driver. As a first step, I would strongly suggest repairing or uninstalling your DAQmx driver and reinstalling it. Yes, the 9.2.3 is compatible with your version of LabVIEW, but make sure that you download the DAQmx 64 bit version driver (and it wouldn't hurt to go ahead and install the newest version, 9.3).
What do you mean when you say it works well in MAX? You mentioned that you did the self-test and it passed, but did you try using Test Panels and were you able to see your signal as expected?
06-08-2011 01:48 AM
I reinstalled DAQmx driver(with version 9.3) as you recommended. Test Panels works well as before(which works well before i reinstalled the DAQmx driver), but still have problem "Error -88302 occurred at DAQmx Control Task.vi:3". Maybe something wrong with LV? I am not sure maybe something missing during installing.
06-08-2011 02:22 AM
I forgot the Code, I attached it.thanks for your help.
06-08-2011 04:50 AM
I also reinstall LV, but still the same. I have no idea now.
I run DAQ assistant it run as show in attachment.
tks for help.
06-08-2011 06:09 PM
Thanks for including your code. I ran it on my machine and it ran with no problems, which tells me that it's something with your system or MAX and not with the code. In the past, when we've seen something like this work in MAX, but not in DAQ Assistant, deleting the Data folder and restarting the system seemed to fix the problem.
Check Step #5 in this document to find this folder. If you delete this folder, you will lose any configurations that you've saved in MAX, so if you have configurations saved that you'd like to keep, continue through the document with steps 6.7, etc. to create a backup of the folder. If not, simply delete the folder and restart your computer and then MAX.
If that doesn't work, try using the MAX Database Corruption Removal Tool to try to clear any traces of corruption that appear to be in your system's MAX.
