Error Building executable (please help i need it for degree thesis)
Hi everybody,
i'm using simulation interface toolkit to control a simulink-real time robotic arm. I tryng to build an executable but appears this error message:
The following files have links to help files that are invalid. Open the files and fix the help link.
C:\----------simulation interface\RVE\RVE.vi
c:\------------------------------------\RVE Editor.vi
details.
error 7 occurred at ABAPI check help files.vi -> ABAPI dist cmq settings to Disk -> EBEp_invoke_buil_invoke.... etc...
Possible reason:
File not found.
My question is:
how i can disable help-file linkage?
thanks everyone. cheers
Message Edited by Laios on 05-21-2008 01:04 PM
Message 1 of 16
(4,150 Views)
Open the VIs and go into the VI properties (File->VI Properties or CTRL-I).  Go to the documentation category and remove or resolve the Help path.
Message 2 of 16
(4,145 Views)
edit:
i've found this page :
http://digital.ni.com/public.nsf/allkb/62AC1049B66DF1D186257114006DDBDF?OpenDocument
the error is exactly that one but help tag and hel path are yet empty.
how can solve it?
Message 3 of 16
(4,144 Views)
but the two form are empty.
thanks for the answer.
Message 4 of 16
(4,142 Views)
Have you checked your subVIs as well?  Perhaps the installer is listing the main VI, but it is one of the subVIs which is causing the issue.
Message 5 of 16
(4,141 Views)
i'm using just one .vi ; not reference to another .vi .....
Message 6 of 16
(4,137 Views)
If you can post your project here, perhaps somone can look at it for you.
Message 7 of 16
(4,135 Views)
http://img231.imageshack.us/img231/9862/error1qx0.jpg
http://img231.imageshack.us/img231/7083/error2na4.jpg
Message 8 of 16
(4,131 Views)
According to the error message, you are referencing two Simulink VIs.  Have you opened the VIs listed in the error message and confirmed there is no help file referenced by them?
Message 9 of 16
(4,127 Views)
So... I opened rve editor.vi and i erased all values in help form. Linked error disappeared but when i can't modify rve.vi because it's protected by password!
how can i find this password?
tks in advance
Message 10 of 16
(4,118 Views)
