Error Building executable (please help i need it for degree thesis)
You probably can't.  With the VI you were able to get to, what was the help file set to?  The other option is to find where that help file went to. and get it back where the VIs expect it to be.
Message 11 of 16
(1,300 Views)
lvsimtk.chm
Message 12 of 16
(1,296 Views)
Do you have that file on your PC.  If there was no path, just the filename, it should be in the same directory as the VI.
Message 13 of 16
(1,292 Views)
I solved copying the help file in the same directory as rve.vi. It was located in the help  folder.
However your help was fundamental.
Thank you very much.
Greetings from Italy. Smiley Wink
Message 14 of 16
(1,291 Views)
another problem !!!! Smiley Mad now whne i try to execute the file appears this message:
http://img241.imageshack.us/img241/8749/error3qt2.jpg
why??? pease help!
Message 15 of 16
(1,287 Views)
Hey Laios,
may this be your case?
Can I Create a Host VI Executable with Simulation Interface Toolkit?
http://digital.ni.com/public.nsf/allkb/77FBEDA8268A89C1862572B4007FD09C?OpenDocument
Greetings
KIM
Message 16 of 16
(1,269 Views)
