Showing results forĀ
Search instead forĀ
Did you mean:Ā
Error Serial Port -1073807202
hi i used the srial port setting to connect to modem using 9600-N-1
this error occurs when i run in the server
but in my computer it works well
need help urgent
(3,788 Views)
Do a search in the forum with that error code and get some informations. If it didn't helps then post your question in bit detail. Now look at this post here.
(3,784 Views)
the run time is cant b downloaded..
any other links..
help plz
(3,772 Views)
Its downloadable for me. ok. try here
(3,770 Views)
