Error during installation of patches and critical updates
My NI Update Service just provided 7 critical updates and patches, which I downloaded and tried to install. However, two installations were unsuccessful andproduced the attached error messages. A possible reason for the errors may have been that the laptop went to sleep during the installation, but I am not sure about that.
My question is how, I can find and try to re-install those critical updates and patches? The NI Update Service does not provide me with a list of installed updates and their status like the Windows Update does. Please advise. Thank you.
(3,769 Views)
Accepted by pbuerki
Update Service saves the suite of installers in C:\ProgramData\National Instruments\Update Service\Installers\NI_date_time. You can try re-running the setup.exe.
If the error happens again, it must be a more general installer failure, but we can look more closely at the error code to debug from there.
LaRisa Mohr
Staff Product Support Engineer - NI Update Service
National Instruments R&D
(3,765 Views)
Hi LaRisa,
Thank you for your quick reply. I found the setup program in the location you described. This time, running the setup went flawlessly. Attached below is the installation summary. I am using LabVIEW 2011SP1 with the Device driver DVD that came with the LabVIEW 2012 Evaluation DVDs. Thismay explain the messages in the NI-DCPower 1.7.5 section. Thanks gain for your help.
Peter
Installation Summary
Installed
LabVIEW 2011 SP1 (32-bit) f2 Patch
LabVIEW 2011 FPGA Module f1 patch
LabVIEW 2012 Real-Time Module f1 Patch
NI-488.2 3.1
NI-DCPower 1.7.5
NI-RIO Patch for using sbRIO-9632/9642 with LabVIEW 2011 and 4.0
NI-Serial 3.9
Installation Details
No software installed or removed.
NI-488.2 3.1
Added or Changed
NI-VISA 5.2
Run Time Support
NI-DCPower 1.7.5
Could Not Install
Core Required Components
NI-DAQmx 9.1.7 (higher version already installed)
NI-VISA 5.0
Run Time Support (higher version already installed)
NI Measurement & Automation Explorer 5.0 (higher version already installed)
NI Spy 2.7.2 (higher version already installed)
NI System Configuration 5.0.0 (higher version already installed)
LabVIEW 2010 (64-bit) Support (incompatible with products already installed)
LabVIEW 2010 (32-bit) Support (incompatible with products already installed)
LabVIEW 2009 (64-bit) Support (incompatible with products already installed)
LabVIEW 2009 (32-bit) Support (incompatible with products already installed)
LabVIEW 8.6 Support (incompatible with products already installed)
LabVIEW 8.5 Support (incompatible with products already installed)
NI-Serial 3.9
Added or Changed
NI-VISA 5.2
Run Time Support
(3,751 Views)
