Array to spreadsheet problem
Hello everyone
I have an array to spreadsheet to write my data into a excel file from the DAQmx which measures pressure, but i get too much data in the measurement part. Do someone know how to get rid of that, because i want exactly the same data as my 2D array in the excel file (one measurement every second).
Thanks in advance
Oesen
Best regards
Oesen
Message 1 of 45
(5,353 Views)
You are building the new data with the old data and that is why you are getting duplicated values. Without using the shift register and try running the code you should be alright.
Message 2 of 45
(5,346 Views)
Thanks for the answer P@Anand
I have removed the shift register now, but it doesn't make any changes. I still get all those values from the "measurement" part in the excel file.
Best regards
Oesen
Message 3 of 45
(5,342 Views)
Which shift register you have removed also how many channels you are acquring?
Message 4 of 45
(5,334 Views)
The DBL shift register, which is connected to the zero array. I have removed this one.
How can i get into this option about channels acquiring ?
Best regards
Oesen
Message 5 of 45
(5,329 Views)
Channel configuration is done in DAQ mx. As expected wrong shift register you have removed, remove the other one (waveform shift register) and test it.
Message 6 of 45
(5,326 Views)
Yes but what should i use as a input source in the left side, when i remove the waveform shift register ?
Best regards
Oesen
Message 7 of 45
(5,323 Views)
You have to something like this.
Message 8 of 45
(5,318 Views)
But i need that code below for zero pointing the chart, when i run the VI.
Best regards
Oesen
Message 9 of 45
(5,304 Views)
You mean you want to clear the chart at first when you run the code?
Message 10 of 45
(5,300 Views)
