Array to spreadsheet problem
I have set the both values to 1, but still getting that problem. It gives 600+ measurement every second 😞
Best regards
Oesen
Message 21 of 45
(2,254 Views)
I don't think I believe that. When I set the sample rate and the number of samples to both 1, I get exactly 1 sample per second, just like it is supposed to.
Message 22 of 45
(2,240 Views)
Thanks for the answer Dennis
I use NI-9237 as a DAQ device
I will try again now:
It still shows the same (many thousands samples per second) ! 😞
Best regards
Oesen
Message 23 of 45
(2,233 Views)
There is exactly 6289 samples in 4 seconds of time
Best regards
Oesen
Message 24 of 45
(2,232 Views)
Where are you looking at and seeing all of those samples? I don't see them at the output of the DAQ Assistant. I don't have your hardware. Perhaps that device has a minimum number of samples. What does the spec say?
Message 25 of 45
(2,222 Views)
Hi Dennis.
I read all those samplings in the .csv file i'm writing to.
If you look at the Sample time (timestamp) and run the VI, it acts like a second the first few second, but it will be more than a second the longer the VI runs.
Best regards
Oesen
Message 26 of 45
(2,213 Views)
Are you using a simluated device or you have a real DAQ card?. Did you try logging with the tdms data logging available with the DAQ assistant?
Did you check the loop rate?
Message 27 of 45
(2,209 Views)
I Use "Internal" as a Vex Source
Best regards
Oesen
Message 28 of 45
(2,205 Views)
Hi P@Anand
I use NI-9237 as a DAQ device.
I have enabled the TDMS logging, but still get the same result 😞
Best regards
Oesen
Message 29 of 45
(2,202 Views)
No after enabling the tdms data logging disable the file you are writing. You do not need that automatically the data will be saved in .tdms format, check the file shown in the tdms data logging configuration.
Message 30 of 45
(2,196 Views)
