03-18-2020 10:23 AM
I am trying to create a LabVIEW 2017 installer and i'm seeing several errors. When I first attempted the install (on a PC without any NI products), I was getting an error saying "you must install LabVIEW 2017 32-bit on the system before you can run this setup". I verified that I have unchecked the checkbox on the installer (in the 'Advanced' tab) saying "Require the LabVIEW 2017 32-bit development system", so I am not sure why I was seeing this error. I then installed LabVIEW 2019 and planned to mass compile everything and create another installer (due to co-worker's success on a different program), but when I did, I saw an error showing that I was missing a driver toolkit, "daqmx.rc" (see attached png). Given that I hadn't seen this with 2017 installer, I reverted back to the original installer and tried again, and now I see a different error when I run the installer (see attached png). This new, current, message says "Missing Key: [nimioi64.msi] Path … correct the ini file and try again". I'm hoping someone can give me a clue on what to do, as I have no clear direction at this point.
