Error generated when using Matlab 7.0 with LabVIEW 7.1
The error (1047) states "Server: Inappropriate input array sizen" no matter what the input is. the script works fine without inputs but there seems to be a problem interpreting inputs. I get this error even when I run the scriptnode example for the Matlab script.
Randall Pursley
(3,942 Views)
I am not too familiar with Matlab and LabVIEW. However, I thought I would attach this link below and see if it helps
Why Do I Get Error 1047 When Trying to Use The Matlab Script Node in LabVIEW?
Sincerely,
Feroz
(3,942 Views)
This is a fixable problem with the older versions of LabVIEW and Matlab, but a new problem with the latest version of Matlab. I have had to 'fix' this problem everytime Matlab upgrades and will probably just have to wait until NI comes out with a new fix to go with Matlab 7.0.
Randall Pursley
(3,942 Views)
I have filed a formal report on this so that the R&D engineers at NI can take a look at it.
Sincerely,
Feroz
(3,942 Views)
In order to keep any further discussion on this topic in a single location, please refer to this thread [broken link removed] for more information.
(3,942 Views)
