Error in NIScope read
Now what I am thinking is as below, is this the normal way to solve it or there any better method,
I will set the read waveform timeout to 0.5s, if it timeout I will ignore the certain error by code(other error still capture), then change the tigger level and read again.
Just wonder why no need start acquisition, afraid of the memory buffer will full before the program run to the reading part.
Thanks.
Message 11 of 11
(301 Views)
