Error occured at CTRL NI-CAN action
This error is showing repeatedly though I connected power supply to the LIN Interface showing this when power off and when on too.pngHardware? Can anyone tell me why is it showing so?
(2,377 Views)
Hi Bunny,
double-check power supply of the LIN port. Triple-check, if needed!
When power supply really is connected with the correct pins: check your CAN/LIN interface for correct operation…
(2,373 Views)
Hi GerdW,
Thank you for your prompt Reply. I checked lot of times whether power supply is connected well But when I clicked on continue Option repeatedly this error is not showing and I am able to use then afterwards. But I just want to know why does it happen like this.
Regards
Bunny
(2,362 Views)
Accepted by Bunny3
Hi Bunny,
We don't know your VI(s) nor do we know your hardware setup: See for yourself to find the cause of the problem!
So this problem only occurs on startup? Then it vanishes in later calls?
Then you don't have a problem at all: just handle that first error programmatically!
(Maybe it helps to power up the LIN port earlier? Maybe it helps to put a wait statement before that ncAction call?)
(2,347 Views)
