Estimation of RSSI Value using SNR
Hello, teachers, I'm currently working on the performance evaluation of wireless communication.
I'm curious about using SNR as a way to measure the RSSI (received signal strength).
The calculation of the SNR is known to calculate the margin value of the SNR with the received signal strength (dB) - signal noise (dB).
So I wonder if I can derive RSSI through the calculation formula of SNR.
(3,125 Views)
Accepted by oyw1022
(3,107 Views)
