Ethernet and Labview V5.01
What kind of machine and what kind of software is running there? If it's an instrument with an ethernet connection, then you could possibly use VISA just like would for a GPIB instrument. If you're required to login via a telnet session, then the LabVIEW Internet Toolkit has a telnet client built from the TCP/IP functions.
Message 11 of 12
(693 Views)
Hello.
I have a very similar problem.  I'm triying to make my own ethernet packets, I don't want to use any know protocol, I need to use my own protocol.  How can I build my own ethernet packets?  I'm using labview 6.i.  I solution with CVI is also wellcome.
Thank you
Carlos Arcediano del Amo
Message 12 of 12
(667 Views)
