Eval Formula Node rounding bug?
Hi-
anyone else found that the behaviour of int(x) is different (wrong?!) in a parsed formula than in a Formula Node or Expression Node?
It seems to behave like floor(x)... (At first I though it was like intrz(), then I checked negative numbers...)
(LV2021.0.1f2, MacOS)
So, 3 problems:
  • Is this a bug- or have I misread the (sparse) documentation for acceptable functions in parsed formulae?
  • Anyone got a workaround in a parsed formula..? -No mod(x,y) of course...!
  • How the hell do you contact Support these days to report bugs..?!
TIA...
~Tom
Message 1 of 15
(4,034 Views)
Hi Tom,
Mind to share some examples for "buggy" input values?
For me (LV2016-32bit, Win10) it seems to behave as described in the help with bankers rounding…
Message 2 of 15
(4,028 Views)
Oh- perhaps a Platform issue- I'll check on a PC in a second..
But here's what I see on a Mac:
Message 3 of 15
(4,024 Views)
Oh- nope- PC too:
(LV21.0.1f2, 32-bit)
Message 4 of 15
(4,020 Views)
Accepted by tomlawton
Hi Tom,
when you debug your example all the way through those FormulaParsing functions you will see the int(x) is translated into function #22, which is executed as "round towards -inf". (Tested with LV2016-32bit). That is not what is described in the LabVIEW help as "round to nearest"…
IMHO you may contact NI support and ask for clarification or a bug report number!
(In my previous post I just checked the FormulaNode.)
Message 5 of 15
(4,000 Views)
Thanks Gerd for digging down to that! (gosh, it's just layer on layer of pure LabVIEW, not quite as nicely wired as I would like, and with scary brittleness, e.g. Function Decomposition.vi; that's not how I'd do that...! Maybe it's for speed...)
Now questions 2 & 3 remain...
Is there a workaround, with just the functions available in a parsed formula?
(for now, since I can, on my own machine I'll just fix Three Register Calculation.VI:
and replace the Round Towards -Infinity with Round To Nearest... Talk about brittle... 😂
And how does one report bugs these days?! Once upon a time, I'd have contacted my NI rep, who would have passed me on to someone in Support... but those days have gone....
Thanks for your swift replies!
Message 6 of 15
(3,989 Views)
Not a nice solution, but you could add 0.5 to the input value.
Regarding support: ni.com/ask
Message 7 of 15
(3,978 Views)
Hi Tom,
That's the worst "solution" you could implement as your program will behave differently on other computers!
You got a much better workaround from Dan - when you don't need bankers rounding...
Btw.:
Why do you want to use ParseFormula including "int(x)" function?
To replicate the "round nearest with bankers rounding" you need something like this:
In the image you also see a corner case: floats allow for "negative zero" while integers don't know about that…
Message 8 of 15
(3,972 Views)
Thanks! That does indeed get around the problem for now- and however un-nice, better than my local fix in vi.lib... 😂
And thanks for the support link- I'll get it reported. Then when they ever fix it, I'll need to remember to stop adding 0.5... 😆
Message 9 of 15
(3,956 Views)
I'm fairly sure int(x) in most languages gets the integer part of a number (thus rounding down), same as doing a Modulo 1 (quotient and remainder).
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 15
(3,934 Views)
