Event Structure Problems
If you are intent on receiving a lot more criticism for impropper coding, just go ahead with that stacked sequence structure.
Message 11 of 25
(1,744 Views)
winterfresh -
the State Machine i've given you can do all of that. Have a go and see what you can make of it.
David.
Message 12 of 25
(1,732 Views)
I haven't had a chance to look at it yet as I'm not on my computer that has labview on it, but ill check it out. Thanks!
Message 13 of 25
(1,724 Views)
Thanks for the replys David but I'm still using LabView 13 and can't open your file,
Message 14 of 25
(1,686 Views)
I can't open LV14 either but here is the very simple case structure method.  Whether or not you decide (or need) to use a more advanced architecture like a state machine is irrelevant.  You should still understand the basic structures in LabVIEW.
Message 15 of 25
(1,669 Views)
ah, okay, not a problem. LV13 saved version attached.
Message 16 of 25
(1,636 Views)
why are we making this issue so difficult?
Message 17 of 25
(1,610 Views)
thanks Apok, I think you have quite nicely proven to us that there are many ways to do the same thing.
Message 18 of 25
(1,584 Views)
David this appears to work, but it runs extremely slow for me, the graph moves every few sconds at best. Is that a function of my computer?
Message 19 of 25
(1,533 Views)
Hi winterfresh -
The graph is only updated each time that particular case is called, which is when the Timeout event occurs. The timeout event is called when the front panel hasn't generated an interrupt or registered event within a particular timeout period. This period is defined by the number wired to the hour glass on the top left fo the event structure. Currently it is the value you originally used, which 10,000 ms, or 10 seconds.
The most obvious approach to resolve the issue would be to reduce that number right down. If you don't have anything you need to handle in other cases or event then you can make the timeout to be quite quick - say, 100ms. You'll just need to play around a little here.
I don't know the full extent of your code but you do have the option in moving your stepper-motor and peak detection code into the timeout event - thus removing the need to have a separate case to 'get value'. If this is a main part of the program and is something you need to happen every timeout period then it isn't a bad idea.
Message 20 of 25
(1,516 Views)
