Event structure following While loop
Try the first occurence trick (as a quick solution there might be a better way)
Message 31 of 52
(2,465 Views)
I didn't know this function, nice one.
Thanks !
J.D.
French Labview beginner
N'oubliez pas de complimenter les bonnes réponses - Don't forget Kudos for good answers
Message 32 of 52
(2,458 Views)
Here is a better way to stop the consumer loop.  Use a boolean instead of comparing the string.  Be sure to set the terminal to Use Default if Unwired.
- tbob
Inventor of the WORM Global
Message 33 of 52
(2,430 Views)
Do you like kudos tbob ? 'cause I do like your help 🙂 thanks
J.D.
Message 34 of 52
(2,396 Views)
It's just incredible how much your code has changed since last week. I am sure you learnt so much in such a short time. Now you can see the benefits of using 'design patterns' such as state-machine and producer-consumer. You remember in the beginning you didn't want to even try them.Keep up the good work.
Don't give me Kudos for that post please Smiley Happy (just an observation, don't deserve it)
Message 35 of 52
(2,393 Views)
Done ! My program is totally converted and works as it did before 🙂 without any Local variable ! (oh there is only ONE!, sorry)
You're right Dimitrios, I learnt a lot, but not only since last week : on the 3rd of may I didn't know labview at all, and I was quite proud of my program as it was a week ago. Of course there was a lot of things to change, and I thank you all for your help and your advices.
I still have to add a lot of functionality, but it will be easier with this template.
But I can't be really happy as there is a big problem with my exe file... (http://forums.ni.com/ni/board/message?board.id=170&thread.id=504487)
Anyway, thank you ! I post my code (without sub VI) if you want to see it (or if you want to give me more advices :p)
J.D.
Message 36 of 52
(2,369 Views)
AAAAIIIEEEE!!!!  Mes yieux.  Mes pauvres, pauvres petits yieux! Smiley Very Happy  JDlabview, you must really like the color orange.
- tbob
Message 37 of 52
(2,357 Views)
LOL!!  I agree.  The color is a bit harsh.
The code looks much better than before.
I could not open your link.
What problem are you having?
Message Edited by Ray.R on 06-15-2010 01:10 PM
Message 38 of 52
(2,349 Views)
this one works better 🙂
Sorry for orange, I promise I will change soon but it's fun at work when people come and react like you did:D
J.D.
Message 39 of 52
(2,342 Views)
Hi, i'm still here 😃
Does anyone can explain me why, whenever an error occur (in any state), my program execute "initialize" case until I force it to stop..
And another behavior : the errors stay when I stop the program and re-launch it. How can I avoid this ?
J.D.
Message 40 of 52
(2,319 Views)
