Examples don't work
Hello everybody!!
I was trying to simulate a 2D map in perspective like the one on attached picture but when I open the examples in the Robotics Module they don't work, I mean, I can open the master .vi without any error and run them, but, the robots don't make any move. In the Goalkeeper example, It doesn't chase the ball, in the balance example, it falls and in the maze example the don't move in though the maze. I installed de f1 patch but nothing has changed. Anyone has found this problem before?
Thanks in advance.
(2,949 Views)
Can you say which Labview software do you use for your simulation and which exemple you have tried to launch ?
Thank you
Alexandre
(2,921 Views)
Hello.
I use Labview 2011. I've tried all the Robotics Simulation examples: Goalkeeper, Ballance, Robots in a Maze, etc. None of those work.
Greetings.
(2,907 Views)
