Executable looking for a VI and failing to launch
Accepted by GerdW
I have now fixed the issue. I installed LabVIEW 2025 Q1 64-bit (I was previously using LabVIEW 2024 Q3 32-bit). I deleted the project and started again with a new one.
Compiled and ran fine first time 🙂
CLA - Kudos is how we show our appreciation for comments that helped us!
Message 11 of 15
(493 Views)
I have similar problem. Almost a year after this thread started and not solution yet?
Message 12 of 15
(410 Views)
The post immediately before yours, #11, has the solution. It was deleting the project and remaking it. I was not able to mark my own post as the solution though!
Message 13 of 15
(366 Views)
Hi Max,
I did that for you…
Message 14 of 15
(357 Views)
The post marked as the Solution is not working for me. Following your advice I installed LabVIEW 2025 Q1 (32 bits) and still I have the same problem.
Updating to 64 bits is not an option for me because I used several packed libraries and rebuild them to 64 bits is too risky for the complexity of the project.
I replaced all the time delay vi, and another missing vi in the executable appeared related to open files or something, it looks like the express VIs are not found.
Could it be a bug to be address by the NI developers?
Message 15 of 15
(330 Views)
