Execution speed and efficiency of Square function
I noticed in many places (including LV built in VIs) that Square function in LabView is substituted with multiplication of the same variable twice. The question is - for double precision digits which is more efficient / fast calculation:
1. When using the Square function
2. When multiply the number by itself (multiplication)
Thanks.
Message 1 of 10
(2,454 Views)
If I recall correctly, it has nothing to do with efficiency; rather, there is a peculiar bug in the x^2 function where it doesn't handle numbers with units correctly.
Bill
CLD
(Mid-Level minion.)
Message 2 of 10
(2,447 Views)
Accepted by topic author peter111
@peter111 wrote:
I noticed in many places (including LV built in VIs) that Square function in LabView is substituted with multiplication of the same variable twice..
No need for conspiracy theories. If you see that a multiplication is used, it means that the code is relatively old and has not been changed (or is is newer code programmed by someone who learned programming before the square was available). Earlier versions of LabVIEW did not have the square function and nobody will go through old code just to update that. Don't touch it if it works correctly!
It is very likely that both versions result in identical binary code under the hood. Use the square function for easier diagram readability and fewer wires.
Message 3 of 10
(2,433 Views)
Here's yet another option:
Obviously an expression node is a 4th option.
Message 4 of 10
(2,403 Views)
But that coerces to floating point (and also upconverts SGL to DBL).
The square function works for integers without coercions (of course you need to be aware of possible range overflow)
Message 5 of 10
(2,398 Views)
If you wire sgls, the output is sgl.
Message 6 of 10
(2,395 Views)
Sorry. Yes, you are right. I had the exponent still at DBL and got a coercion dot at the lower input, Did not investigate further.
The fun start if you go complex: The x^y function might give you some fuzzy digits. 😉
Message 7 of 10
(2,385 Views)
Yes, I thought that was what happened.
That's weird, last I checked both 2 and 0 can be represented exactly in binary.
Guess there's some magic going on to support the more generic X^Y case. Good to know, although I probably forgot it by the time I run into it (if ever).
Message 8 of 10
(2,380 Views)
It may not be the reason why it was done this way, but I was right.  And it is a bug.  I don't know if it's been resolved.
Bill
CLD
(Mid-Level minion.)
Message 9 of 10
(2,313 Views)
It appears that they have fixed it:
Message 10 of 10
(2,297 Views)
