‎03-08-2010 01:05 PM
running LabVIEW 2009.0f2 (32 bit) with a cRIO. In LabVIEW I have a FIFO input where I read a byte, and I need to look for a match in a table (block memory). can anyone point me to an example doing something like this. I seem to be having a hard time finding examples of memory manipulation on an FPGA.
thanx
lmd2
‎03-09-2010 04:35 PM
This is a good place to start.
http://zone.ni.com/reference/en-XX/help/371599E-01/lvfpgahelp/using_memory_fpga/
Are you using block memory or a lookup table?
‎03-09-2010 09:13 PM
Hi Anna
thanx for the response but I was hoping for an example that could optimize searching for a match. Specifically my FIFO will be a stream of bytes, after say a dozen clock ticks I will have data in a dozen registers. Then I want to search a table of data in block memory (or a look up table) for a set (or row) where elements 2,3,4,6,7,& 11 match registers b,c,d,f,g,& K
I don't expect to find an example doing exactly this, but I can't seem to find any examples of searching memory on an FPGA, using on-chip look-up tables, ... I can grasp the concept, I know that it is doable, but I don't know enough to figure the best approach or even what my options are; and there doesn't seem to be much out there for guidance
thanx anyway
lmd2
‎03-10-2010 10:45 AM
actually if there aren't any examples doing a search and match,
maybe someone could point me to a white paper or tutorial on using look-up tables on an FPGA, or any related material on how to efficiently search memory?
thanx
lmd2
‎03-10-2010 02:25 PM
‎03-10-2010 03:20 PM
thanks, I'll check out the LUT example - the speed factor sounds great but size may be an issue. my dynamic input (FIFO) will be 16 bytes read as two 64 bit numbers (so two clock ticks). out of those 128 bits some will be one-bit flags, but some will be ASCII (bytes). The static memory (LUT) will hold dozens of sets, each set maybe 20 bytes and I need to search for the set that matches a subset of those dynamically acquired ASCII characters. I am sure that I can code this, but I am just as sure that it won't be optimized (I am a LV architect, but am still new at FPGA coding) - was hoping for a slick example, guess I'll just have to wing it.
Thanx for the info
lmd2
‎03-11-2010 08:49 AM
‎03-11-2010 09:04 AM
