FPGA rational resampler
Hi!
Im working on a project and I use a compactrio 9040 with 4 x NI 9224 modules. I wish to resample  data from the modules from 1000 S/s to 20 S/s using the rational resampler on the fpga. But it does not work as I want, it seems like my output data is rather ~22 S/s.
My question is if  I use the resampler and FIFO incorrect somehow?
Currently I wait for the outputvalid signal before sending it into the FIFO, is that the correct way to deal with?
Please see the attachments.
Best regards
Martin
(2,169 Views)
Hi Frid,
Nothing appears (at least to me) to be wrong with your resampling setup, so I wonder if one of the following is true:
  • The input is being delivered more frequently than 1000 times/second (even though the sample rate of the modules is 1kHz max) - maybe you're delivering duplicates and not waiting for new samples? (the outer loop, not visible in your screenshots, would be what to consider here)
  • You're measuring the ~22 S/s wrongly (I'm sure you were careful here, but I'll point it out anyway just in case)
Is it possible either of those is true?
GCentral
(2,109 Views)
