FPGA synthesis: "Error generated from encrypted envelope"
I am new to LabVIEW. I tried to add a very simple VHDL code into a PXIe-5764 (chassis PXIe-1062Q, PXIe-8840). I tried to follow the tutorial present in the online help (CLIP Tutorial: Adding Component-Level IP to...). Then I want to run my project, but the compilation by Vivado fails with
ERROR: [Synth 8-5809] Error generated from encrypted envelope. [C:/NIFPGA/jobs/Tf9tGWE_wwJ8U9O/DemoClipMult.vhd:46]
Attached is the complete Xilinx log.
Thank you
PS Labview 2019 (64-bit) 19.0
Message 1 of 12
(6,791 Views)
My problem might not be related to CLIP. I have another simple VI without VHDL code that does not compile any more on the local machine. I get the same result with LabVIEW FPGA Compile Cloud Service.
Let me put things together:
I am new to LabVIEW, and LabVIEW FPGA (but I have some expertise in FPGA and Vivado)
Following tutorials, I created a simple VI that I could compile using the Cloud Service.
Then I installed Vivado using the NI Package Manager, and I could compile locally, which was much faster.
Following tutorials, I created a CLIP.
But now I am not able to compile any more. Neither the simple VI, nor the CLIP.
Thank you
Message 2 of 12
(6,716 Views)
To confirm that your config is correct, can you compile and run the Getting Started example for the 5764?
What version of Windows are you using?
Can you use the IP Integration node? (so you can simulate it)  Has the VHDL been verified outside of LabVIEW FPGA?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 3 of 12
(6,686 Views)
It seems I can not run the Getting Started example any more. It worked once. See attached.
Windows version is 7 Professional, SP 1.
"Factory Image 2.0.1f0". I have also accepted some Windows updates.
Thank you
Message 4 of 12
(6,649 Views)
I am in the same exact boat as you with this error. I looked on some other sites and they suggested upgrading Xilinx?
Also, the directory (the part after the jobs/....) where the error occurs doesn't exist for me. Is this the same for you?
Message 5 of 12
(6,624 Views)
Hi bchang32,
I have installed Vivado using the NI Package Manager, so I presume it is the right way... I did not try to update it.
I presume the jobs/ directory contains temporary files used during compilation, so I am not surprised they do not exist any more.
PS: I just discovered I can update LabVIEW, and LabVIEW runtime to 2019 f2
Message 6 of 12
(6,610 Views)
PPS: I just updated to 19.0f2, but it does not help.
Message 7 of 12
(6,590 Views)
Thank you
Your issue is configuration.  I would first focus on getting the Getting Started example for the 5764 to run (as it comes from LabVIEW).  Maybe uninstall and reinstall?  Or repair installations?
ALE Consultants
Message 8 of 12
(6,559 Views)
Using NI Package Manager, I have "repaired" Vivado. It does not help. Then I have "repaired" all components (takes a few hours), reboot the system, but today the system refuses to start up. It seems like there is a power issue: complete shut down about 3 seconds after power up.
Message 9 of 12
(6,538 Views)
In the meantime we had to replace the PXIe-8840 Controller. For some unknown reason it was broken. Then I could start again and compile several time the project under development. But today I face again the synthesis issue: "Error generated from encrypted envelope". More precisely, here is the log:
LabVIEW FPGA: The compilation failed due to a Xilinx error.
Details:
ERROR: [Synth 8-5809] Error generated from encrypted envelope. [/opt/apps/NIFPGA/jobs2/Tn4kQpj_Fhz0mjh/threshold.vhd:92]
ERROR: [Synth 8-5809] Error generated from encrypted envelope. [/opt/apps/NIFPGA/jobs2/Tn4kQpj_Fhz0mjh/threshold.vhd:94]
ERROR: [Synth 8-5809] Error generated from encrypted envelope. [/opt/apps/NIFPGA/jobs2/Tn4kQpj_Fhz0mjh/threshold.vhd:96]
ERROR: [Synth 8-5809] Error generated from encrypted envelope. [/opt/apps/NIFPGA/jobs2/Tn4kQpj_Fhz0mjh/threshold.vhd:99]
One strange thing is that threshold.vhd is one of my source file (CLIP), but it is limited to 80 lines. I presume the full path is related to the cloud computing I am using. This time I still can compile the Getting Started example for the 5764.
I would really like to know what this error means.
Edit: Using a local compilation, I could track the file C:/NIFPGA/jobs/***/threshold.vhd, which is longer, but encrypted! No way to understand.
Message 10 of 12
(6,276 Views)
