FPGA time sistematically off
hi
I'm using 2 target to host DMA FIFOs to transfer acquired data to the host PC (see picture).
In the FPGA vi, whitin the while loop, I use a Wait (in microseconds).
Whatever the value "dt" given to this Wait, in the host I recollect data with a systematic error in time:
every 10 points the time elapsed is not dt but (dt+1 microsec).
It's a small error, but becomes significant when dt needs to go below 10 us, as I need, and makes the analysis harder.
This behavior is always identical and not random (I get ten good "dt", then one dt+1 microsec, and back again).
I wonder if I do something wrong or if it's an intrisic problem.
(2,726 Views)
Accepted by fpdx
You should try using a Sequence Structure:
Per the help documents:
To manage execution rates with the Loop Timer Express VI, place the Loop Timer Express VI in the first frame of a Flat Sequence structure or a Stacked Sequence structure and put the rest of the code in subsequent frames.
EDIT:
You should also note that the first iteration may be off.  There is nothing that can be done about this (from what I understand).  But after the initial loop, every other execution will follow quite strictly to your timing selected by the Loop Timer Express VI.
If someone helped you out, please select their post as the solution and/or give them Kudos!
(2,700 Views)
solved, thanks.
The problem was that I was using the Wait function, instead of the Loop Timer.
Once switched to Loop Timer, using it in the first  frame of a sequence structure, the time between points is finally constant.
(2,670 Views)
