09-06-2006 10:19 AM
09-07-2006 01:42 AM
09-07-2006 05:07 AM
Back to my original problem, I've noticed that it happens every time the FPGA VI reference is not closed properly. If the host VI's execution is aborted with the FPGA VI reference still open, in the next run the interrupts stop coming and the only way to get them working again is to restart the computer (which probably does some kind of reset to the FPGA hardware). Software reset of the FPGA VI reference through the Invoke Node doesn't work either. Does anyone know how to reset the FPGA without restarting the computer?
Vladimir
09-07-2006 05:59 PM
09-08-2006 03:24 AM
Hi Mike
Thanks for your reply. I am actually using the "Open and Run" option. The FPGA VI is re-run again correctly even after an Abort and is working well, except for the interrupts. However, I've recently found out that it is sufficient to restart LabVIEW to get the interrupts working, so now it is not as annoying as restarting the whole computer. I think I can do with it now, and I'll try to make my programs bug-free, so that I won't have to use Abort Execution too often
Vladimir
09-11-2006 03:35 PM
What version of the NI-IMAQ I/O driver are you using?
Joseph D.
09-12-2006 05:55 AM
