Failure "E:\lv45\mgsource\textmgr.c line 3651
I get the above failure now and again when I try to open or run a specific vi. This vi uses a chart and is similar to other vi's I use. It seems to work without problems somedays and on other PC's.
At present I cannot get the vi to open or run and I cannot even see the diagram on my development PC. Any help would be appreciated.
I use windows 98 with a P3 .
(2,509 Views)
This problem has been documented before, and the cause has been traced back to a code error in the computer's video driver. There are several Knowledge Bases that discuss this issue. You can find these Knowledge Bases by going to www.ni.com and doing a search for 1IAFOMG4 or 1G2HG523, which are the ID's for the two Knowledge Bases.
Ryan Tamblin
Applications Engineer
(2,509 Views)
