Fieldpoint Error detail searching solution
while deploying the projects(using Fieldpoint Hardware).it is deploying successfully but when i run my host program. giving some error in TCP/IP connection
error :
using two VIs
1  acquiring data vi. it acquires data using FP Read.VI
2. host program .
it is using TCP/IP for making connection but giving some error.
(Error 63 occurred at TCP Open Connection in TCP _IP_host.vi->Main_Host.vi
Possible reason(s)
LabVIEW:  Serial port receive buffer overflow.
LabVIEW:  The network connection was refused by the server. For TCP/IP, make sure the server is running and listening on the port you are trying to use. Firewalls can also cause a server to refuse a connection. For VI Server,make sure you have enabled VI Server from Tools>Options>VI Server:Configuration.)
Prashant Soni
LabVIEW Engineer
Message 1 of 8
(3,358 Views)
HAve you defined the correct port number? Have you disabled the firewall as the error says?
Message 2 of 8
(3,352 Views)
yes i have disabled the firewall
what could be the port address
 i have given 2055 as the port address
Prashant Soni
LabVIEW Engineer
Message 3 of 8
(3,343 Views)
Message 4 of 8
(3,341 Views)
Accepted by Prashant_S1
Got it solved? Can you update?
Message 5 of 8
(3,332 Views)
Dear muks,
 problem is solved thanks
in labview
.>>Tools>>option>>vi server.configuration
in this i select TCP/IP
set Port Address
and the same port address give into the TCP/IP VIs
and the problem become ok.
but now there is another problem
that is ...
system is waiting for RT Response
you want to stop or disconnect that
according to my analysis , this problem may come due to Time out
Prashant Soni
LabVIEW Engineer
Message 6 of 8
(3,327 Views)
I suppose you have to add some delays. Can you post a screen shot of what you are trying?
Message 7 of 8
(3,324 Views)
Dear
pls here is the screenshots
Prashant Soni
LabVIEW Engineer
Message 8 of 8
(3,321 Views)
