File Size Issue
@bugsmashers wrote:
And it's a good excuse to upgrade the PC too!! Smiley Wink
Once you clean up your code, it may no longer be necessary for the PC upgrade, so get the new PC soon and blame it on the PC.
Message 11 of 17
(1,619 Views)
I use local variables whenever it is not terribly simple to wire things together. Do the locals take a lot more space?
Don't worry about space if you're passing an I32 or a DBL or something small, but the bigger the structure you're passing, the more wasted space locals consume. That's because when you read a local, you make a COPY of the data it contains.
Steve Bird
Culverson.com
LinkedIn
Message 12 of 17
(1,613 Views)
Well, there's your problem. You need to have your code much more deeply nested. Keep grouping things functionally.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 13 of 17
(1,548 Views)
Oh yes, one more thing... Good large professionally-written applications don't look large, or even very complex. That is the key.
A good book to read about software development in general is: "Software Fundamentals: the collected papers of David L Parnas". It's not about LV specifically, but it will teach you 99% of what you will ever need to know about writing code.
Mike...
LabVIEW Champion
Message 14 of 17
(1,547 Views)
Thanks, I'm overwhelmed by the response.
Ben
Message 15 of 17
(1,542 Views)
Wow Mike,
This brings back memories..  It's been a while since I've seen the name David Parnas.  I went to one of his conference many moons ago.  Very good reading, for sure.  I think he was a professor at Queen's U (Kingston).
As for the recommendations within this thread, it looks like everyone points towards smaller function-specific vi's.  😄
Message 16 of 17
(1,530 Views)
Currently he's at Limerick in Ireland, and isn't doing any more writing Smiley Sad . All his recent publishing has been limited to the slides that accompany his lectures. I would love to have the opportunity to hear him speak sometime.
Mike...
LabVIEW Champion
Message 17 of 17
(1,522 Views)
