Find array in 1D array
@altenbach wrote:
@Valentin87 wrote:
Below I attach picture with example what need to realize
Flatten both to string and search string.
Nice first thought but will we not run into complications since there is not eight bits in the match pattern AND the match could happen across characters?
Ben
Message 11 of 17
(2,456 Views)
No, unless you use 4.x mode, boolean arrays are stored one byte/element.
(see also the image I have now attached to the earlier post)
(Of course it also assumes that the boolean arrays are "normalized" for lack of a better word, else all bets are off. :D)
Message 12 of 17
(2,452 Views)
The solution in #9 will work if you have an exact match.
If there is a chance the match is not exact, this will work:
Message 13 of 17
(2,442 Views)
@Ben wrote:
A basic suggestion is to search for the first element of your "target array" and only when you find a match on the first, proceed to check the residual data for a match.
Ben
Here's how this could look like. 😄
 This now also works for all other array datatypes, but will only find exact matches, of course, so be careful with floating point comparisons. It can be easily modified to find all matches if there are more than one.
Message 14 of 17
(2,434 Views)
Accepted by Valentin87
Here's how that could look like. The size of the output array is the number of matches. If it is empty, no matches were found.
Message 15 of 17
(2,424 Views)
Could you attach this as VI saved in LV2011?
Message 16 of 17
(2,407 Views)
LAbVIEW 2011 does not have conditional tunnels, so you would need to do some simple workarounds. You should be able to implement the earlier version that only returns the first match.
The code is quite trivial. What parts prevent you from creating the code from scratch? Have you done some tutorials?
Message 17 of 17
(2,404 Views)
