05-29-2015 08:05 AM - edited 05-29-2015 08:06 AM
@Hooovahh wrote:
nyc wrote:
What is gained without him doing anything?
Meh I'm with crossrulz some times. If I were looking for a Fletcher Checksum VI I know I could do it,
You could do, but that is not the point. The OP didn't even bother trying.
I increasingly see a lot of laziness on these message boards.
People expecting to be given something without even attempting to make an effort.
I have always learned more by doing than getting a handout.
05-29-2015 09:09 AM - edited 05-29-2015 09:10 AM
It is easy to get jadded on the forums. I wonder if we need a support group. Maybe a dedicated subforum for people to say thanks, and give stories of how they went from zero to hero because of the direction and help of experts.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
05-29-2015 09:33 AM
@Hooovahh wrote:
@nyc_(is_out_of_here) wrote:I increasingly see a lot of laziness on these message boards.
Fact is uncomfortable for some people.
05-29-2015 09:48 AM
I never said anything about being uncomforable, and I didn't say anthing about denying facts.
06-02-2015 01:51 AM
I finally do one myself that work like I need. This is the VI:
The case structure is is for adding zeros if necessary (it takes the digits in groups of four)
06-02-2015 06:40 AM - edited 06-02-2015 06:42 AM
You should have stated that you wanted a U64 as the input. And then that you just wanted the lower non-0 16 bit words.
You have plenty of Rube Goldbergs in there. For instance, change your Scan From String to output a U16 and you can simplify your combining of the sums to a simple Join Number. You could also make the format for the string be %4x. This would eliminate the need for the String Subset since you could just keep the remaining string in a shift register.
And your adding of zeros I think is done at the wrong place. They should be added to the front of the string, not the back.
And building on the code I already gave you, here is a much smaller version of the code that does the exact same thing.
