FlexRIO 6581 Timing violation need help
Hi all,
I need some help, in the enclosure code, I have timing violation when I compile it. Does somebody can take a look, to help me to optimize or change something in order to compile the code ?
Thanks. Marc
(2,962 Views)
Accepted by topic author Marc-Henri
Where do you get the timing violation?
From a quick look, try replacing the x2 (multiply with a constant of 2) in Write DIO.vi with a bit shift of 1 bit.
Also, do all the values have to be U32? Always use the smallest representation possible. You can even change the representation of the tick counter.
(2,955 Views)
I have a timing violation in the big SCTL in the middle with the state machine Idle/ReadRam/Generate. You're right about the U32, I don't realy need them.
Any other suggestion ?
Regards Marc.
(2,952 Views)
More important than the U32 is the multiply I mentioned.
(2,950 Views)
Thanks to you dan_u
(2,929 Views)
