Jay,
I have to say I`m no programming Guru, but isn`t a State Maschine based on a
case (Switch) statement? This statement does allow the user to hop to and
fro within a certian pre-defined space, but the use of a GOTO is, as far as
I am aware, not limited to a particular region of the code. At least with a
switch statement (Case) the beginning point of each "choice" is well defined
and fixed, therefore reducing the change of mistakes.
just my 2 cents
Shane
Jay schrieb in Nachricht <3a919621@newsgroups.ni.com>...
>Hey, Tim. You say:
>>I believe that the loop exit capability wasn't included because it was
considered
>bad programming practice, like using goto's.
> That's funny. How can it be any worse (or different) than putt
ing exit
>logic into a While-Loop? As for Goto's, they're the basic logic behind the
>much revered State Machine, and no one seems to mind that. If you're not
>careful, State Machines can wind up producing some pretty good spaghetti
>code, just like any text-based code can do.
>Jay
>>> Original message: Why don't For-Loops have a premature exit capability
>--- i.e. why didn't NI include the exit capability that exists in other
languages?
> Is it a dataflow thing? I don't see how. Just curious.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
