For loop in a while loop
@altenbach wrote:
Since a FOR loop that iterates zero times basically does not do anything new, here's another silly solution; 🙂
(Also, there is a +1 primitive that you don't even need if you would adjust the random range accordingly. "x+y" is not a useful label, there needs to be a way to stop the while loop. The while loop probably also needs some timing, etc.)
I agree that we would need significantly more context to find a good solution to whatever the OP is trying to
do. e.g. by looking at the real code and not some stripped down example.
  • Is the while loop a toplevel while loop?
  • What is the purpose of the FOR loop?
  • How does it relate to the overall user experience when running the program?
I missed the simplified vi (I think it came in while I was typing a reply), but I agree that it leaves too much context out to understand the real application.
Message 11 of 14
(1,445 Views)
And if you don't like red (coercion dots) and green (booleans), one could do as follows: (still silly!!!)
Or even ...
Message 12 of 14
(1,439 Views)
What I'm not understanding is the Poly instance.   Am I really missing something?  Isn't there a U8 instance?
Message 13 of 14
(1,432 Views)
No, only U64, I64, and DBL.
(Also note that there are bugs!)
Ideally, this should be a VIM where the output adapts to the input representation of the lower and upper limit. 😄
Message 14 of 14
(1,425 Views)
