For loop taking way too long to execute
Hello fellow LabVIEW users
I have encountered huge problem that following for loop takes way too long to execute, I need to run two same for loops like the following one and they both together take horribly long time - 18 seconds on average. Surprisingly, when I combined both loops it took even longer.
For loop above is doing (or should do) following part of code:
for i = 1 : 11850
    signalAvr(i) = signal(i);
    for j = 1 : 149
        signalAvr(i) = signalAvr(i) + signal(i + j);
    end
end
Is there any way of speeding up this loop? What am I doing wrong?
Smdx
Message 1 of 8
(5,658 Views)
The build array is taking a lot of time because it is constantly grabbing more memory.  Instead, use the autoindex tunnel to build your array.  LabVIEW will preallocate the memory for the array and will run a lot faster.
Message 2 of 8
(5,632 Views)
One thing that is absolutely killing you is the fact that you're reading a local variable 1765650 times each time you run this vi.
Message 3 of 8
(5,629 Views)
I think you are doing it way to complicated.
Try this:
NOTE: My local variable is somehow **bleep**ed. The reference control together with the property node should be a local variable.
Message 4 of 8
(5,628 Views)
Accepted by Smdx
I haven't fully tested it, but see if this will work for you.  It is a lot simpler.
EDIT:  Ok, dkfire beat me to it.  At least we came up with the same solution independently.  I just use the autoindex tunnel where he preallocated the array and replaced elements.  Both ways will get you the same result.
Message 5 of 8
(5,623 Views)
Use the Code Capture Tool, it is so much better than the built-in LabVIEW snippet menu choice.  It doesn't break locals and references.
Message 6 of 8
(5,606 Views)
Looks like you guys beat me to it, but I will post my solution anyways.SigAvr.PNG
***EDIT: I need a shift register in the inner loop and should be autoindexing on the outer loop****
Message 7 of 8
(5,605 Views)
That solution will not work.  For that method, you need a shift register in the inner loop and you should be autoindexing on the outer loop.
Message 8 of 8
(5,600 Views)
