Showing results forย
Search instead forย
Did you mean:ย
For loop
How can I create shift registers at left side of for loop  in count of 4 and at right side of for loop in count of 1 as in the image attached here. Thanks in advance!for loop.jpg
Best Regards,
Dhans ๐Ÿ˜‰
Kudos are welcome ๐Ÿ˜‰
Aspirant Labview Programmer (Labview 14) ๐Ÿ˜‰
(4,249 Views)
You can have multiple Shift register at right side, but extending of same **bleep** register is not possible at right side, only left side shift register can be extended to get mutiple iterated value.
Whats the need for having extended shift register at right hand side?
Palanivel Thiruvenkadam | เฎชเฎดเฎฉเฎฟเฎตเฏ‡เฎฒเฏ เฎคเฎฟเฎฐเฏเฎตเฏ†เฎ™เฏเฎ•เฎŸเฎฎเฏ
LabVIEWโ„ข Champion |Certified LabVIEWโ„ข Architect |Certified TestStand Developer
(4,244 Views)
Accepted by topic author dhans
  1. Basically shift registers stores the values from the previous iterations.
  2. Place a For loop and righ click on the loop you can find Add shift register from the sub menu.
  3. Like in image that is called stacked shift registers, again right click on the shift register from sub menu you  can find add element.
(4,235 Views)
Thanks for all!!!
Best Regards,
Dhans ๐Ÿ˜‰
(4,226 Views)
