borderless modal window
cross post from lava:
https://lavag.org/topic/13639-create-a-proper-borderless-vi-without-the-raisedembossed-look/
How to get rid of raised frame when using modal window? I made my window transparet to use custom shapes in splash screen but this borter remains and can't be turned off in modal window...
Message 1 of 8
(5,728 Views)
In the Properties uncheck window has title bar and check whether it works for you or not...
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 8
(5,717 Views)
That is not the case, see image below:
Window is transparent so I can have customised shape.
Message 3 of 8
(5,683 Views)
Did you check with this Community example?
https://decibel.ni.com/content/docs/DOC-1086#/?page=2
-Looks exactly what you might require when you run example 5 in that post.
uday
Message 4 of 8
(5,670 Views)
Thanks for reply.
I have checked that example. Everything works good until I set this window as modal. When window is modal I see frame around my transparent window that looks bad.
Message 5 of 8
(5,654 Views)
Why are you so intent on the splash screen being modal?  When I think of splash screen, it is the only window open until the app has initialized and is ready to be displayed.
aputman
Message 6 of 8
(5,636 Views)
share your code, because i can able to make my Screen with borderless during Modal.
it will be easy to debugg with your code!
Message 7 of 8
(5,616 Views)
Simple example attached
Message 8 of 8
(5,608 Views)
