Force a combo box to only work as a drop down
@zou wrote:
Customize the ComboBox.
See attached.
Nice! And with a little tweak it should look like the System one (although it doesn't automatically update the looks)
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 35
(715 Views)
It seems that the combo box has a "bling spot" and unchecking the "Allow undefined values at run time" is not making the control bullet proof - here is a valid sequence how to force the combo box to yield undefined value by using just mouse clicks and keyboard presses during run time:
  1. You have a combobox with few items, "Allow undefined values at run time" is of course unchecked
  2. Run your application (in EXE or within LabView) and click on the edit field, just like you want to edit the content. You'll notice that typing has no impact on the shown value or you can select some of available items.
  3. And here is the "blind spot" - press with mouse at the beginning of the combo box string (before the first character) and then press <Delete> button - the text will disappear and now if you click away from the combo box the void value will reside in the control. If you have an event for the combo box change, at this moment you'll get a void string.
Because of this flaw I'm trying to avoid combo box controls.
BTW, the custom combo box control posted above also suffers from the same "blind spot" problem.
Message 22 of 35
(586 Views)
Empty string is a problem for ComboBox.
If config the ComboBox as following, when select the empty string from the pull down menu, it returns empty string instead of 2.  See test VI in 2018.
George Zou
Message 23 of 35
(520 Views)
Agree,
the empty string is the weak point of the LabView combo box .
Enum / Ring types can behave as combo boxes (and I use them for this purpose all the time), but they don't have the small arrow to remind the user to press there are select the record.
Luben Hristov
Message 24 of 35
(509 Views)
Pulldown Enum & Ring attached.
George Zou
Message 25 of 35
(491 Views)
This modified control works better, but has another non critical flaw - if the text is too long it overlaps the arrow key.
I guess you used the standard enum & ring controls and customised them - you resized  the arrows on the left side and moved them on the right side, the arrow down is overlapping the arrow up. Also the arrows stay on layer below the text field, so when you click on the arrow you technically click in the enum/ring text field, which naturally shows the pull down menu.
Another inconvenience is that it's a custom control (type cast) and you can't just drag/drop it from a common library location and use it. After dropped on the panel, first you need to break the typecast link to the original *.ctl file and then save it to a new file (failing to do so may result in entangled misbehaviour - by changing a file in one project you may affect other projects which use the same typeCast control in wrong way).
Message 26 of 35
(477 Views)
Another problem of the modified enum/ring control (with the arrow placed below the text layer) is that if the text is centered it appears "screwed" because the centering is taking in account the whole width of the text field (including the covered with the arrow area) - see the effect below:
Message 27 of 35
(421 Views)
You can use the system style.  Both ring and enum are pulldown.
George Zou
Message 28 of 35
(413 Views)
That's it! Use the System style enum and ring to get proper pull down arrow behaviour.
Message 29 of 35
(405 Views)
@Mads wrote:
Good idea, thanks 🙂 It comes off visually a bit hackish / far from other system controls (regular system rings etc) though. George Zou's edited control is 95% there and would work 100% if not required to mix with other similar system controls.
@Mads:
Hope this version is close enough to what you want.
George Zou
Message 30 of 35
(375 Views)
