10-07-2025 04:10 PM
This new version changes background color automatically when change from control to indicator.
10-08-2025 02:24 AM
Looks good,!
BTW how to remove the thin red line around the box - it's not fitting to existing control styles.
10-08-2025 11:08 AM
Oops. I accidentally set the red component to a wrong number.
Thanks Luben.
It's fixed now.
10-08-2025 02:27 PM
Hi George,
Thank you - this control works well!
There is still one "blind spot" and you can output in some circumstances void string, the "fooling" sequence is:
1. Click on the control, for example it can show A (the character is also selected).
2. Instead of typing a letter or up/down arrow keys (which work perfectly) press the left arrow few times until the cursor moves before the string
3. Then press Delete or any letter, which is not part of the list (for example in the original control any letter except A, B and C) and the control will show blank value.
10-08-2025 04:23 PM
I am not trying to fix the empty string bug. In fact, you can't fix this bug by customizing the ctrl.
What you can do this call NI to report this bug and get a CAR#. Hopefully NI will fix it.
