Formatting text string into correct columns
Greetings,
I am able to read data from a text file and to remove the comma for each data point using a While Loop, this part works. Now I need to acquire the first 0-9, 10-29, and then 30-49. 0-9 are columns, so under the first column is 0,10, and 30; the second column would be 1,11,31; etc. Does anyone know how to separate this so that I can plot the first column, the second column, etc?
Thank you for your help,
PIC
(3,233 Views)
PIC,
Depending on the form of your data, you may not need to do a lot of rigorous parsing work at all.  Look at Read From Spreadsheet File.vi, Reshape Array.vi, and the Index Array.vi to extract your columns.
-cb
(3,228 Views)
i think this is what you want........Smiley Wink
(3,225 Views)
Thank you for your suggestion. It has lead me to other avenues to explore.
Thanks again
(3,186 Views)
