Front panel Tab control page change
I am trying to create a Labview GUI to control a motor. I use a tab control in which on page 1, it is all about the control of motor and page 2 for the configuration of motor controller. I wanted to make the GUI work in the way that when I click page 2 of the tab control to configure the motor controller, the motor stop by itself. To implement this, the act of clicking on page 2 must change something or produce a number, just like the button "ok".
Does anyone has any idea how to implement this? I could have used a separate button to stop the motor but I am trying to make a more user-friendly GUI.
(4,009 Views)
Accepted by Trainee123
Just use an event for the tab control in an event structure.
(4,006 Views)
Teritask's message will do what you want.
But I question whether causing the motor to stop because you changed the tab control is a good idea.  I wouldn't call that a user friendly GUI experience.  When I'm working with tabbed controls in any application, not just LabVIEW, as a user,  I don't expect the behavior of the application to change just because I wanted to view a different page, and I certainly wouldn't expect something physical to happen like the shutting down of a motor.
A friendlier user experience would allow a user to view other pages.  If they happen to change some configuration values on that page while the motor is running, then when they click an Apply button or something like that, then the application should warn them that doing so will require the motor to automatically stop.  Then you'd have an OK/Cancel dialog box to allow them to back out.  If they cancel, then the changed values would go back to their original values.
(4,001 Views)
