GSM modem
hello,
me too I am facincg the same Problem, instand of getting the Ok response I am getting what I sent,
How to set that carriage return ?
I am using the shown VI.
Thx.
Message 41 of 45
(1,062 Views)
Right click on your string control and select '\' Codes Display Display.
Message 42 of 45
(1,057 Views)
thx,
i finally got it
by using this VI:
Message 43 of 45
(1,051 Views)
Just to be clear, your original code would have worked.  You just needed to set your string control to show \codes.  You probably had it set for normal mode, and thus were sending AT backslash r backslash r.  If it was set for \codes and you entered AT\r\n, then LabVIEW would have known you were have known you were trying to send carriage return and linefeed instead of the literal characters of backslashes "r" and "n".
Message 44 of 45
(1,037 Views)
Sir can u help me, how are u sending the SMS , i am trying but i am failing..
Kind Regards,
Joseph
Message 45 of 45
(1,007 Views)
