Generate A Report and Save In PDF
Hi All,
Attached VI i am working on.,
Here I'm trying to generate a report by appending chart image into that and save the report as pdf.
But i coudnt able to save it in pdf.
In the path dialog box,eventhough i give file name as.PDF,still i coundt able to print in pdf and when i tried to open it became corrupted.
please help out of this
(5,088 Views)
Accepted by Dskp
I started down the "save as PDF from Word" path a while back but I've never gotten around to completing the VI.  I believe what you'll need to do is use "Word Get ActiveX References.VI"  and document.SaveAs2 method (invoke node).  You need to wire an integer "17" to the variant "file format" input.
(5,068 Views)
Accepted by Dskp
Find link for PDF file saving.
https://decibel.ni.com/content/docs/DOC-25831
Bijay
(5,031 Views)
HI,
Thanks..It worked for me.
(5,017 Views)
